What version of PI do you recommend for small scale network with 2*9800 Catalysts, 2*5520 and 3*5508 controllers and with a mix of 350+ APs. (including 9Ks)
You should open a TAC case if you have to restart PI every so often. If it’s a VM, make sure your hardware meets the requirements especially with IOPs.
We have issued related to AP bandwidth performance too low.
Scenarios
Cisco Aironet1832i convert to the controller ( Cisco Mobile Express) and other AP joined controller as well.
We try to test bandwidth from AP to provide SSID and got bandwidth ar...
view more
Access Points disjoins and joins the WLC frequently. It's a new AP here are the logs that were observed. %CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: Session-IP: *************************** CAPWAP DT...
view more
Ladies and gentlemenI've got a problem here. For unknown reasons, the controller is 5520 while it's version is 8.1.123, and it's an old device.
Recently, I found that the portal authentication we did ourselves cannot automatically jump after linking...
view more
I have a small AP network running that has been running quietly and happily for a couple years. Recently one of the AP1815i-B-K9 failed and all that I could lay hands on quickly was an AP1815W-B-K9. It appears to come up normally and appears in the ME con...
view more
Hello, I hope someone can help me figure out how to set up manually specific Tx power levels, channels and channel width in the 9800 series controller for each AP or groups of APs. Thank you in advance.
