Cisco WiFi Overkill for Homes
830
Beginner
Looking to provide wifi overkill in my home. It's two story with a basement. I am thinking two aironet 1600's. What do you think?
Let me know if there is some other model I should be looking at.
3 Comments
Hall of Fame Community Legend
If you want to "overkill" then a 9800 for the WLC and deploy Catalyst 9130ax in every room (including the garage).
Hall of Fame Master
Oh… just like me Leo:) I do have 9800 and ap’s in every room not the garage. Total of 6-9, but I do a lot of testing. I think you need to understand what you can afford first, and then also understand that without support, you will not be able to upgrade or downgrade unless you find the software available in the internet.
Beginner
issue got solvedd10.0.0.0.1
Content for Community-Ad
