Oh… just like me Leo:) I do have 9800 and ap’s in every room not the garage. Total of 6-9, but I do a lot of testing. I think you need to understand what you can afford first, and then also understand that without support, you will not be able to upgrade or downgrade unless you find the software available in the internet.
To change the fonts on your form:Click Themes in the header of your account.From the Theme dropdown menu all the way to the left, select an existing theme or create a new one.Select Typography from the list of properties.Under Typography, select the text ...
view more
Hi, i'm still here...like @rrudling told me, latest firmware for many AP series have the "404 not found" bug, and also the ap3g2-k9w7-tar.153-3.JF15.tar for AP2600i has it! but i don't want the easiest way and i'm now asking you how to conf...
view more
I have a virtual Cisco 9800 soon, I will have a fiscal Cisco 9800.Is it possible to have an HA between my virtual Cisco 9800 and my physical Cisco 9800?
I am trying to fetch the AP radio down information, I am referring https://github.com/YangModels/yang/tree/main/vendor/cisco/xe/1711 for fetching the API. Unfortunately I am unable to get that from the above github repository,
Question regarding configuring the Band Select option on RRM in the 9800 WLC. From what I understand, Band Select will work like this;client RSSI < Client RSSI WLC setting (Min Value) == no probe response returnedMid RSSI > client RSSI > (Mi...
view more
