Define WLAN ID for Cisco 9800 WLC using Prime Infrastructure
268
Beginner
  I'm trying create a template to configure a WLAN on a 9800 WLC. I want the WLAN to have a specific ID. How can I set the WLAN ID in a template?
4 Comments
Hall of Fame Master
If it’s not available in the template, then you can’t. Make sure that your PI supports the 9800 that you have.
Beginner
Scott,
 Thanks for the reply. I running ver 3.7.1 which does support the 9800. I'm able to push templates to apply wlan configurations but, I cant set the Wlan ID.
Hall of Fame Master
If the option is not there, then that is something you need to either wait for or open a TAC case and suggest a feature request. You can always create the ssid on a controller, take the configuration for that specific ssid and then use a cli template to push that out to the 9800’s. That would be the workaround.
Beginner
Yes, I think I will need to open a TAC.
Content for Community-Ad
August's Community Spotlight Awards
