TM13
  Anybody knows how to pull detailed report that showing all APs CDP neighor switches of WLC? Can see one by one through CDP->AP Neighbor, but we have almost 300 APs and bulk report of that, we have Prime.
2 Comments
cmarva
Level 4
Level 4
you can set up an AP report from the report launch pad.
device > inventory > then report type APs. in the pop-up, custom report name AP inventory. for the data fields, select neighbor name, neighbor port, etc.
TM13
Amazing, thanks Cmarva, this is exactly what i wanted!
French webcast-routing
