Number of internal antennas in 2800 or 3800 access points?
illusion_rox
Dear Experts,
I tried looking at datasheets but couldnt find this info. Can someone tell me or point me to the document which specify the number of internal antennas for 2800 and 3800 APs?
6 Replies 6
Scott Fella
You look at the number of spatial streams and that tells you how many tx and rx antennas.
https://www.cisco.com/c/en/us/products/wireless/aironet-3800-series-access-points/index.html#~benefits
-Scott
t.matsudo
We can see Figure 5. Picture of the embedded antenna system and 3D antenna heat maps
in Cisco Aironet Series 2800/3800 Access Point Deployment Guide; <https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01001.html>.
I understand that AP2800i and AP3800i have 4 antennas of 2.4/5GHz Dual Band for Macro-Cell.
I understand that AP2800i and AP3800i have 4 antennas of 5GHz Band for Micro-Cell.
illusion_rox
So is it part of standard that number of spatial streams equals number of TX and RX antennas?
t.matsudo
I understand that the IEEE 802.11 standard only specifies the number of spatial streams and that the standard does not specify the number of physical antennas.
Scott Fella
The data sheet tells you, it can be 3x3x3, 4x4x3, 8x8x4, etc. the first two are the tx/rx and the last is the SS.
-Scott
Xiaoyao_998
For 11ac device , it was no 8x8 connect , only 4x4 from one ssid and update to 4 layer steams.
