Javier Contreras
Happy to Introduce “Wireless Config Analyzer Express” the next gen cloud based evolution of the WLC Config Analyzer (WLCCA) with powerful checks for Wireless LAN Controllers , Access Points (AP), Radio Frequency (RF), Mobility, Security, Mesh and Flex Configurations. “WCAE” provides state of art RF summary including stats summarization at WLC, AP group, Flex group level and RF health analysis at WLC, AP group, Flex group level.
Please access the tool in the tools section of Cisco.com @ https://cway.cisco.com/wireless-config-analyzer/
WCAE Main Features (Feb 2018)
Config Checks
184+ checks for configuration issues, covering Security, WLANs, Mobility, Mesh, Flex, etc
Get the experience of hundreds of cases applied to your network in seconds
AP  Data Summarization
Get list of AP HW types and operational modes in use
RF Stats
Quick data summarization for main RF stats,  see what is happening at WLC, or AP group/Flex group levels
RF Health
Simplified RF analysis tool, translate those RF statistics into simple Health report
Log File Summarization
List all messages in a short list, get counts and initial/end time
Supported Controllers
WLC running AireOS
Any version
Any Hardware
File Types Supported
Sh run-config -> recommended option, gives you more bang for the buck
Sh tech
Sh msglog
WCAE is a public facing tool and anyone with a valid CEC ID can enjoy its benefits. Please feel free to share this tool with your customers and partners.  Note: Ensure that pop-up block is disabled for the page on your browser to run the script. Here are some cool screenshots from WCAE:
Controller Messages View
 Controller MessagesController Messages
RF Health view
 RF Health viewRF Health view
More information
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/212795-wireless-config-analyzer-express.html
Integration
The same backend engine is used on the Diagnostic Bridge as part of the Connected TAC initiative, you can join your network and  enjoy additional digitized expertize: https://www.cisco.com/c/en/us/support/services/connected-tac/index.html
Feedback
 Feedback buttonFeedback button
Questions? Features requests? Problems?  Please let us know!~
9 Comments
Aaron Hilley
Any chance we can get an export button?  PDF and CSV?
Javier Contreras
Hi Aaron
Yes, we are planning on export feature for future release
regards
In this moment, we can´t use this app... any problem?
Jacob Snyder
Level 5
Level 5
Curious on where the export feature stands.  Would love to see json as an option.
or, api access so we can get the results directly.
blakekrone
Level 4
Level 4
I agree, we should be following the DevNet lead allowing an API access to get all of the information via JSON. Would love to be able to use Python to push a config file up to the platform, have it analyzed, and return all the data in a JSON structure for consumption.
jagjeet.singh
Hi ,
this tool is not working , please suggest how to use it .
Javier Contreras
Hi Jagjeet
I just tested, and the tool worked fine, could you unicast me what file types are you trying to use?
The tool uses "sh run-config" output, either in text or ZIP compressed formats
regards
Bruno Dinis
hello good night.
Can anyone explain why there's not an offline tool for that?
People might not want to share specific configurations with cisco.
Thank you in advance.
bruno
Jacob Snyder
Level 5
Level 5
Bruno,
there is an offline version of this tool.  It’s called WLCCA (Wireless LAN Controller Config Analyzer)
This web tool is the “Express” version.
https://community.cisco.com/t5/wireless-mobility-documents/wlc-config-analyzer/ta-p/3119057
French webcast-routing
