Jeffrey Keown
Some 5520 and 8540 controllers shipped from the factory without manufacturing installed certificates activated.
The first symptom typically observed is the inability to access the controller via https. (Temporary workaround: enable http access.  CLI: config network webmode enable)
Code upgrades will also fail due to an unactivated certificate:
FTP Code transfer starting.
FTP receive complete... extracting components.
Failure while validating the signature!
This issue is documented in the following bug:
 CSCuv97685    5520 or 8540 may have no Manufacturing Installed Certificates
This condition can be recovered without replacing the unit.
Refer to the following document for the recovery procedure, or contact the Cisco Tac for  assistance:
https://supportforums.cisco.com/blog/13046816/recovery-missing-85405520-manufacturing-installed-certificates
6 Comments
Scott Fella
Great info. Anyway you can post the solution?  We actually ran into this today.
-Scott
George Stefanick
Thanks for sharing .. So what is the fix and what date range of equipment is impacted ?
Jeffrey Keown
Hi Scott,
Done.  added another blog post with the recovery procedure.  Original post edited with link.
Jeffrey Keown
Hi George,  take a look at the release note for this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy67885/?reffering_site=dumpcr
Scott Fella
Thanks Jeffrey!
sotoncisco
Beginner
Beginner
This is just tremendous
"More Info:This problem is supposed to have been addressed by manufacturing for all units built after 9 September, 2015.
Unfortunately, the manufacturing process change did not fix the problem."
French webcast-routing
