AireOS cannot "schedule" when an SSID can go up/down, however, newer 9800 WLC can.
The only way to do this with AirOS are the following:
Use Prime Infrastructure;
Use time-based ACL to enable/disable the VLAN of the AP (NOTE: This means the AP will go offline);
Use EnergyWise to turn the power off/on of the AP
