Bahman
We're running WLC 9800-40 with version 16.12.2t with SFP-10G-LR-S. I have some questions regarding SFP-10G-LR-S:
1. Is this model supported by Cisco? If not Which model do you recommend for WLC9800-40?
2. Would SFP-10G-LR-S cause issues with upgrading of WLC 9800-40 to newer IOS version, such as 16.12.3 and 16.17.xx?
Bahman
2 Comments
Rafael E
You can find SFPs supported on the following link.
The model you mention in this post is not listed so, it is not recommended for the 9800-40 WLC
would that cause priblems with upgrade - it is hard to tell, but I can tell you if it is something we do not support you can expect any type of behavior.
Feichti
Hi @Bahman
I had the same question to our contact from Cisco. They told me that the SFP-10G-LR-S are supported but not listed in the SFP List.
But i askt for the 9800-80 Controller not the 9800-40. But i think thats the same.
I have a Pair 9800-80 in HA with the SFP-10G-LR-S running with Software 16.12.3
Regards Tobias
French webcast-routing
