This Document shows us how to add the aIOS AP on to any NMS device what we have - WCS/NCS/PI
Config on the AP
1>> Configure the Community on the AP with the Community Name With Read/Write (RW) permission
2>> Configure the SNMP host IP address with the community name
Here are the command for the same on the AP..
ap(config)#do sh run | i snmp
snmp-server community <community name> <access level - ro/rw>
snmp-server host <NCS/PI/WCS IP addr> <Community name>
Example
snmp-server community maibpi RW
snmp-server host 10.106.60.111 maibpi
Config on the PI/NCS/WCS
1>> From the NCS GUI Go to COnfigure >> Access Points
2>> From the Drop Down, Select ADD Autonomoous AP
3>> Fill in the details and hit on ADD
4>> If Added Details are correct then this is how we see on ther PI GUI...
5>> If we click on the AP this is how it looks
TROUBLESHOOTING
>> Just in case if we are failing to add APs,
1>> Make sure the config on the AP is correct and pointring to the right Community and the PI address
2>> Telnet / SSH credentials should be set same on both the AP and the NCS
