wingcambodia
 what are different between AIR-AP1830-K9-8-8-100-0.tar and AIR-AP1830-K9-ME-8-8-100-0.zip?
Leo Laohoo
The TAR is a CAPWAP image file.
The ZIP is APs running Mobility Express.
lukaszziaja
<br />
Do you mean files from: Downloads Home/Wireless/Wireless LAN Controller/Mobility Express/Mobility Express for Aironet 1830/Cisco Mobility Express - 8.8.100.0 ?
<br />
If so and If you have CAPWAP AP already with AirOS 8.8.100 and want to change type to Mobility Express you need to download AIR-AP1830-K9-8-8-100-0.tar from Cisco.com to sftp/tftp server. To change the ap type you have to use CLI command "<sftp/tftp>://<server ip-address>/<filename with path from root>
<br />
If you have AP working as a Mobility Express controller with earlier version (example 8.6.x and you want to upgrade to 8.8.100 you have to use AIR-AP1830-K9-ME-8-8-100-0.zip. You can do it via GUI using HTTP, TFTP, or Cisco.com using your Cisco credentials.
<br />
To do all above you have to have valid support contract.
<br />
Regards, Lukasz
lukaszziaja
If so and If you have CAPWAP AP already with AirOS 8.8.100 and want to change type to Mobility Express you need to download AIR-AP1830-K9-8-8-100-0.tar from Cisco.com to sftp/tftp server. To change the ap type you have to use CLI command <sftp/tftp>://<server ip-address>/<filename with path from root>
Regards, Lukasz
lukaszziaja
If so and If you have CAPWAP AP already with AirOS 8.8.100 and want to change type to Mobility Express you need to download AIR-AP1830-K9-8-8-100-0.tar from Cisco.com to tftp server. To change the ap type you have to use CLI command "ap-type mobility-express tftp://<server ip-address>/<filename with path from root>
Regards, Lukasz
lukaszziaja
Regards, Lukasz
