AP's fail to register in a WLC 2106 ver 6.0.196.0
1074
I have the following configurations yet the AP give the errors below
*Dec 14 20:30:14.494: c8:bc:75:c9:27:54 Received a Discover Request from e8:4f:75:29:77:24 via IP broadcast address but the source IP address (10.20.5.70) is not in any of the configured subnets. Rejecting the request
AP are configure to receive ip address in the 10.20.5.0/24 subnet where the DHCP is also configured.
DHCP CONFIG
int vlan 5
ip add 10.20.5.1 255.255.255.0
no  shut
ip dhcp pool AP
option 43 ip 10.20.2.2    (should this be 10.20.2.3 <AP management address>)
default-router 10.20.5.1
network 10.20.5.0 255.255.255.0
ip dhcp exclude-address 10.20.5.1
Interface Configuration
Interface Name................................... ap-manager
IP Address....................................... 10.20.2.3
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.20.2.1
VLAN............................................. 2
Primary DHCP Server.............................. 10.20.5.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
Interface Name................................... management
IP Address....................................... 10.20.2.2
Primary DHCP Server.............................. 10.206.1.5
Also, can I use the option 43 ip (ip of wlc management_address) rather than the option 43 hex (hex TLV)
Can anyone help me with a reason the AP are not registering?
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.196.0
RTOS Version..................................... 6.0.196.0
Bootloader Version............................... 4.0.191.0
Emergency Image Version.......................... 6.0.196.0
Build Type....................................... DATA + WPS
Thank  you for your posting and interest in the Cisco Support Community.  For  best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions.
For  technical questions related to a Cisco Product or Technology, we  encourage you to post on the Network Professionals Forum (NetPro).
For your  specific question you can go to Wireless  - Mobility - General forum
Content for Community-Ad
August's Community Spotlight Awards
