B clients cannot connect to the AP, while A and G clients connect without a problem
618
Core Issue
Data rates are not configured properly.
Resolution
There is a problem with the data rate settings.
To properly connect different client adapters with 802.11B cards, make sure that data rates 1, 2, 5.5, and 11 (mbps) are set to require and that all other data rates are set to enable. The 802.11B cards do not understand the 54 mbps data rate, so the cards do not work if the data rate is set to require on the connecting Access Point (AP).
For more information on configuring the data rates on the AP, refer to the Configuring Radio Data Rates section of Configuring Radio Settings.
For other factors that affect wireless communication, refer to these documents:
Content for Community-Ad
