Can a Cisco Aironet 802.11b AP support WPA2 and AES?
5364
Introduction
Resolution
Cisco Aironet 802.11b APs do not support WPA2 and AES.
WPA 2 is supported on this equipment:
  • Aironet 1130AG AP series and 1230AG AP series
  • Aironet 1100 AP series
  • Aironet 1200 AP series
  • Aironet 1300 AP series
Note: Equip these APs with 802.11g radios and use Cisco IOS  Software Release 12.3(2)JA or later.
Note: WPA 2 and AES is also supported on Cisco Aironet 1200 series radio modules with the part numbers AIR-RM21A and AIR-RM22A. However, the Cisco Aironet 1200 radio module with the part number AIR-RM20A does not support WPA 2.
Note: Cisco Aironet 350 series products do not support WPA 2 because their radios lack AES support.
For more details regarding the installation of an IEEE 802.11g-compliant radio in a Cisco Aironet 1100 or 1200 Series AP, refer to Cisco Aironet 802.11g Radio Upgrade Instructions.
To learn more about how to configure WPA2, refer to Wi-Fi Protected Access 2 (WPA 2) Configuration Example.
For more questions related to Wi-Fi Protected Access, WPA2 And IEEE 802.11i, refer to Cisco Wi-Fi Protected Access, WPA2 AND IEEE 802.11I.
Problem Type
Release notes / product  overview / data sheet / FAQ
Products
Access point
Radio Type / Standards
802.11b
Security Options
WPA
Reference
Create
Recognize Your Peers
Content for Community-Ad
