The Cisco 2100 series of wireless LAN controllers (WLC) provide a cost effective unified wireless solution for small businesses as well as remote or satellite offices. Although the 2100 series WLCs have multiple 10/100 ports, like the larger WLCs, they do not behave like switches or routers. The 2100 is a software switch without full IPv4 connectivity between the individual ports; so it is not good idea to use the different ports as a hub/switch implementation. Understanding this fundamental point is a key aspect of getting the best performance out of the controller.
Because of the lack of full IPv4 support between the individual ports, the 2100s are designed to have a single network connection. This means that all of the interfaces, i.e. management, ap-manager, and dynamic interfaces, on the WLC should all be assigned to the same physical port. Configuration Example 1 shows a 2100 using port 1 as the network distribution port for the WLC.
(2125wlc) >showinterface summary
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager 1 39 192.168.203.4 Static Yes No
datanet2 1 44 5.5.3.100 Dynamic No No
guest 1 900 5.5.5.100 Dynamic No No
management 1 5 192.168.5.76 Static No No
thirty-five 1 35 192.168.35.76 Dynamic No No
twenty-five 1 25 192.168.25.76 Dynamic No No
virtual N/A N/A 1.1.1.1 Static No No
(2125wlc) >showport summary
STP Admin Physical Physical Link Link
Pr Type Stat Mode Mode Status Status Trap POE
1 Normal Forw Enable Auto 100 Full Up Enable N/A
2 Normal Disa Enable Auto Auto Down Enable N/A
3 Normal Disa Enable Auto Auto Down Enable N/A
4 Normal Disa Enable Auto Auto Down Enable N/A
5 Normal Disa Enable Auto Auto Down Enable N/A
6 Normal Disa Enable Auto Auto Down Enable N/A
7 Normal Disa Enable Auto Auto Down Enable Enable (Power Off)
8 Normal Disa Enable Auto Auto Down Enable Enable (Power Off)
Notice that in the above configuration example, all of theinterfaces on the WLC, aside from the virtual interface, are all assigned toport 1. Port 1 is the only physically connected port on the unit to the wirednetwork.
A common misconfiguration with the 2100s is to physicallyconnect multiple ports on the WLC to the switched network. The logical reasoning behind this is toincrease bandwidth because the ports on the 2100s are only 10/100. In theory, thismakes a lot of sense considering the 2100s can support up 25 APs, included the802.11n models. In practice, however, you will commonly see traffic flow problems with this type of deployment. These traffic flow problems usually boil down to ARP issues that are a direct result of the software switch nature of the device.
The traffic flow problems that result from multiple networkconnections stem from two major causes. The first is that when you havemultiple network connections to a WLC, you must either use ling aggregation(LAG) or have an ap-manager interface assigned to each port. This ensures proper traffic flow into and outof the WLC. With the 2100s, however, youcannot configure more than one ap-manager interface and LAG is not supported. The second issue is that all of theinterfaces on a 2100 use the same MAC address. This fundamental design aspect is the underlying cause for the followingbugs files against the 2100 series controllers:
Known Defects/Bugs
CSCsj33229 - Unable to ping AP's directly connected to a2106 controller
CSCsw43518 - Users connected to directlyconnected AP's not able to pull IP address
CSCsk15792 - Ethernet bridging doesn't workif RAP is directly connected to a 2106
CSCtf26554 - Delay of LWAPP request frame periodically sendingfrom LAP
From the above list of issues, you can also see that having APs directlyconnected to the WLC can be problematic as well.
You can have problems were directly connectedAPs will not join the WLC and have PoE issues if using ports 7 and 8.
CSCtg09589 Duplex Mismatch When 1140 AP is Directly Connected to 2100WLC
CSCte24079 2106LAN hangs after high load with duplex mismatch
CSCsg23834 - 2106 AP in connected mode cannot join controller
CSCsl46609 - 2106 POE does not power AP properly
For the best results, you will want to have all of your APs on a networkswitch as opposed to having them plugged into one of the remaining WLC ports. This goes against the current marketing material for the 2100s and a request to the Technical Market Engineers has been sent to have this information corrected.
The following are some simple logical diagrams illustrating what is best practice and what designs should be avoided:-
Best Practice - Only a single networkconnection between the WLC and the switched network. APs are not directly connected to the WLC,but instead are connected to a network switch.
Example 2: Incorrect – Multiple connections from the WLC to the switched network
Example 3: Incorrect – Although there is only a single network connection between the WLC and the wired network, APs are directly connected to controller.
Example 4: Incorrect – multiple connections to the wired network from the WLC and APs directly connected to the controller. One of the directly connected APs is using PoE.
