Huan Guye
Community Member
Introduction
Pict1.jpgCisco Wireless LAN Controllers work in conjunction with Cisco lightweight access points and the Cisco Wireless Control System (WCS) to provide system wide wireless LAN functions. As components of the Cisco Unified Wireless Network, Cisco 2100 Series Wireless LAN Controllers present network administrators with the visibility and control necessary to effectively and securely manage business-class WLANs and mobility services, such as voice, guest access, and location services.
The Cisco 2106 Wireless LAN Controller works in conjunction with Cisco lightweight access points and the Cisco Wireless Control System (WCS) to provide system wide wireless LAN functions. As a component of the Cisco Unified Wireless Network, the Cisco 2106 Wireless LAN Controller gives network administrators the visibility and control necessary to effectively and securely manage business-class WLANs.
The Cisco 2106 Wireless LAN Controller provides:
  • A cost-effective solution for enterprise branch deployments and small and medium-sized business environments
  • Business-class RF security and WLAN security policy monitoring
  • Simplified network deployment, operations, and management to help reduce overall operational expenses
These controllers are part of a Payment Card Industry (PCI) certified architecture, and are well suited for retail customers who deploy transactional data applications such as scanners and kiosks. With performance up to 100 Mbps, the Cisco 2100 Series Wireless LAN Controllers also enable small and medium branch offices to deploy collaboration applications such as guest access and mobile voice.
While Cisco 2100 Series Wireless LAN Controllers support transaction-oriented wireless environments such as handheld scanners in retail, the Cisco 5500 Series Wireless Controllers are recommended for high-data-rate and multicast-intensive applications such as large data files, video, push-to-talk.
Features and Benefits
Features and Benefits of the Cisco 2100 Series Wireless LAN Controllers
Features
Benefits
Eight 10/100 Ethernet Ports
Provides eight 10/100 Ethernet ports, intended to support a combination of access points and redundant LAN uplinks
Power-over-Ethernet-Enabled Ports
Two of the eight 10/100 Ethernet ports are 802.3af Power over Ethernet (PoE) and Cisco PoE enabled, rated for use with Cisco Aironet® lightweight access points
Small Form Factor
Allows for convenient desktop mounting or rack mounting, with optional rack mount kit for flexible deployment
Extended Secure Coverage
Extended secure coverage for larger stores and warehouses
PCI Integration
Supports a PCI-certified architecture for retail customers
Support for 802.11n
Offers robust coverage with 802.11 a/b/g or delivers unprecedented reliability using 802.11n and Cisco Next-Generation Wireless Solutions and Cisco Enterprise Wireless Mesh
Cisco 2100 Series Models and Number of Access Points Supported
2100 Series Controllers
# of Access Points Supported
Cisco 2106
6
Cisco 2112
12
Cisco 2125
25
New Features
Cisco Unified Wireless Network Software Release 6.0 is supported by the following devices:
• Cisco Aironet access points running Lightweight Access Point Protocol (LWAPP)
• Cisco 2100, 4400, and 5500 Series Wireless Controllers
• Cisco Aironet 1524 Outdoor Mesh Access Point
• Cisco Catalyst® 6500 Series/7600 Series Wireless Services Module (WiSM)
• Cisco Wireless LAN Controller Module (WLCM) and Cisco Wireless LAN Controller Module Enhanced (WLCM-E) for integrated services routers
• Cisco Catalyst 3750G Integrated Wireless LAN Controller
• Cisco 3300 Series Mobility Services Engine
• Cisco 2700 Series Wireless Location Appliance
• Cisco WCS and Cisco WCS Navigator
PRODUCT LITERATURE
Bulletins
All Cisco 2100 Series Wireless LAN Controllers Bulletins
Cisco Unified Wireless Network Software Release 4.0 206.0
Data Sheets
All Cisco 2100 Series Wireless LAN Controllers Data Sheets
Cisco 2106 Wireless LAN Controller Data Sheet
Q & A
All Cisco 2100 Series Wireless LAN Controllers Q&A
Cisco 2100 Wireless LAN Controller Q&A
Cisco Unified Wireless Network Software Release 4.0.197.0 Q&A
Wireless LAN Controller (WLC) Error and System Messages FAQCross-Navigate
anilkumar.cisco
Level 4
Level 4
Very good document, thanks..
One question, Can we recover the password for Cisco WLC 2106.. ??
If factory default is the only option then can , can we take the backup of the WLC with FTP and then restore to factory default and then restore it back after resetting of the password..
Best Regards
Anil Singh
svshow
All the links are broken :(
