Cisco Mobility Services Engine (MSE) Error - One of the hard drives in the RAID-1 array has failed
1094
Introduction
In this document Cisco TAC engineer " Samson Aloor " has explained about issue Cisco Mobility Services Engine (MSE) Error - One of the hard drives in the RAID-1 array has failed
Problem Subcategory
2700 Location Appliance/MSE
AIR-MSE-3355-K9
Problem Type
Hardware Failure
Software Version
7.4.110.0
Problem Details
The login screen is showing that the RAID-1 array has failed. is this cosmetic software bug?
Cisco Mobility Services Engine: AIR-MSE-3355-K9
One of the hard drives in the RAID-1 array has failed. Please contact Cisco Customer Support
immediately for assistance and further guidance.
[root@xxx-xxx-xxx-xxx ~]# show vudi
RUNNING HARDWARE VALIDATION TESTS for MSE-3355 Mon xxx xx xx:5x:x3 20xx
ALL      HARDWARE      TESTS      PASSED
Cause / Problem Description
When user login to the MSE he sees error message "RAID-1 array has failed"
Workaround
Check if the /etc/motd file has the error message. If so, clear the contents of this file. If there is a /etc/motd.bak file and it has the proper contents, copy this file to /etc/motd. This should fix the error message issue.
More Information
This bug is a duplicate of bug CSCtj07375
Content for Community-Ad
