Cisco PI Error - Pre collection check failed, Device Reachable but Unmanaged state
2524
    Introduction
    Error - Pre collection check failed, Device Reachable but Unmanaged state on Cisco Prime Infrastructure.
    Scenario 1
    User running Cisco Prime Infrastructure 1.3 with 100 Eval LifeCycle license installed. Discovery for WLC worked fine and all controllers were discovered.
    But when tried to discover a Switch, the reachability tab says Reachable but the Status tab shows Unmanaged.
    When clicked the Unmanaged tab it says " Pre-collection check failed because:"
    The SNMP is configured correctly. User put a sniffer and could see 3 SNMP request and 3 SNMP replies.
    Solution
    The licence count for 100 devices (Eval Limit) was consumed as soon as WLC is added. On PI page https://<server-name>/webacs/welcomeAction.do#pageId=LicenseCenter_pageId look at how many are taken and if it is in violation.
    When upgraded to 500 pack it still didn't fix the issue after re-syncing. We had to remove the device and re-add.
    Scenario 2
    User running PI 1.3.0.20 and has a 100 Eval LifeCycle license installed. He had 137 devices managed in routers and switches. About 24 devices are shown as Reachable but Unmanaged and still show that way after a Sync. Confirmed the proper SSH and SNMP credentials were specified.
    Enabled traces and capture logs to troubleshoot.
    2013-03-XX 11:XX:24,70X [http-XXX-31] INFO inventory - The device 24XXXX04 with IP
    XX.X.XX.XX is in UNMANAGED state.
    2013-03-XX 11:XX:24,70X [http-XXX-31] INFO inventory - The device 24XXXX04 received for
    collection is in unmanaged or maintenance state
    2013-03-XX 11:XX:50,35X [ICE Service[ 1]Thread: 14] INFO inventory - XX.X.XX.XX
    24XXXX04 (IP: XX.X.XX.XX) will not have its features collected due to Precollection check failed
    because: All licenses (100) consumed, need to add more licenses
    Solution
    Since we were over the device limit, tried deleting a few switches until we had enough available devices. Add the switch back and it came managed without a problem. Therefore, the issue was caused by the license limit being reached.
    Reference
    Cisco Prime Infrastructure Configuration Guide, Release 1.3
    Release Notes for Cisco Prime Infrastructure, Release 1.3.0.20
    Cisco Prime Infrastructure 1.3 Quick Start Guide
    Cisco Prime Infrastructure - Troubleshoot and Alerts
    Source
    This document was generated from the following discussion: Device Reachable but Unmanaged in Cisco Prime Infrastructure 1.3
    Content for Community-Ad
    August's Community Spotlight Awards
