Cisco PI WorkFlows for Converged Access (CA) -Single Switch Branch Network WorkFlow
493
 Viten Patel is working as Technical Marketing Engineer (Converged  Access) at Cisco. He was working as Wireless Escalation Engineer -  Cisco TAC and holds many wireless certification like CCIE Wireless,  CCNP Wireless, CCNA Wireless, CWNA, CWSP, CWAP, CWNE#146.
This document explains about the Prime Infrastructure WorkFlow for Converged Access. There are 3 WorkFlows (Small network, Large network and Centralized network deployment). This section shows the single switch Small Branch flow.
Below is a reference topology and deployment scenario
The WorkFlow helps deploy the above mentioned features. With just a few clicks you can deploy multiple branch networks with all the wired / wireless best practices for Converged Access.
What is achieved?
Some of the benefits of using the WorkFlow includes --
  • Simple to use
  • Masks the configuration complexity
  • Highly scalable
  • covers most of the deployment scenarios
  • configure onces, use many times model
  • intelligence and best practices inbuilt in the tool
  • deploy the network with simple user data inputs
More Information
Very good!!!
Thanks so much
Content for Community-Ad
July's Community Spotlight Awards
