TCC_2
Level 10
Level 10
Core Issue
Need assistance determining the 340 series and 350 series product differences.
Resolution
The differences between the 340 and 350 series Cisco Aironet products are few in number, but may have a significant effect on your use of the products.
  • The 340 series radio transmit power is 30mW, while the 350 radios transmit at 100mW, thus providing greater effective range.
  • 350 series Access Points (APs) and bridges support inline power, provided either by a powered switch port or by an ethernet power injector, allowing for deployment in more varied locations without being dependant on a nearby power outlet.
Problem Type
Technical product specification / features
Products
PCM 340, 350
AP 340, 350
BR 340
BR 350
Workgroup bridges
PCI 340, 350
