wannabe22
Community Member
Hello everone
i'm a new is cisco, i have a Ironet AP 1142N, and have some trouble with this, because i don't have much experience with cisco.
well i need to setup this with the next config:
need 2 SSID, one SSID Called ServiceRoom and other called Visitors, the ssid called visitor only with internet access and the ssid ServiceRoom access to internet and other net resources.
need 3 vlan , vlan 10 to ServiceRoom, vlan 20 to visitor and vlan 30 only for administration.
the ssid called visitor assign ips for DHCP with the range 192.168.10.160, and deny the next ip range: 192.168.1.1, 192.168.2.0, 192.168.3.0, 192.168.4.0, 192.168.5.0, 192.168.6.0.
the two SSID need encryption wep 40bits.
use both 2.4 and 5 GHz bands if the clients support it, depending on radio signal, etc.
note: sorry for my english xD
Thanks a lot
Best regards
wannabe22
Community Member
ok, i'm back.
this is my config but i have a problem, the two SSID is created and show me but i can't connect , when he ask me a password don't connect.
this is my actual config.
somebody can help me and say me what is wrong with my config, please
thanks
Building configuration...
Current configuration : 2900 bytes
version 12.4
no service pad
service password-encryption
hostname AP0001
enable secret 5 $1$9NC3$xBq9q.3vbURZFD2G2LlPQ/
no aaa new-model
dot11 syslog
dot11 ssid AP_ServiceRoom
   vlan 10
   authentication open
   mbssid guest-mode
dot11 ssid AP_Visitors
   vlan 20
   authentication open
   mbssid guest-mode
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 10 key 1 size 40bit 7 8D0678EA90D3 transmit-key
encryption vlan 10 mode wep mandatory
encryption vlan 20 key 1 size 40bit 7 CA374880ECD8 transmit-key
encryption vlan 20 mode wep mandatory
ssid AP_ServiceRoom
ssid AP_Visitors
antenna gain 0
mbssid
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
ip address 192.168.20.165 255.255.255.224
ip access-group visitors in
ip helper-address 10.100.10.60
no ip redirects
no ip unreachables
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
ip address 10.100.10.165 255.255.255.224
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
