Here is a case a centralized 802.1x authenticator is used,so the access devices like APs and LAN switches are asked to support transparent EAP pass through.
If enable HREAP with both "local-switching" and "local-authentication" checked and set both layer2 and layer3 security to "none",whether the EAP messages can be sent out from the AP wired interface?
