12-23-2019 02:37 AM - edited 11-18-2020 03:13 AM
what does the cloud entry mean? is this a cloud service, you are referring to?
what does that mean?
@Scott Fella @Supermantech
When AP receives the Flexconnect group it is supposed to join either through cloud provisioning or via a previous WLC configuration (say primary WLC) then it by joins the "SAME GROUP" name in Secondary WLC by default as a "Cloud" entry.
If tat particular AP is added as a member of some another flexconnect group (different than as in primary WLC) in secondary WLC, then it overrides the prev Flex group name it received from primary WLC and joins the Flex Group its added into in Secondary WLC, this is called an "Admin" entry.
