10-13-2010 06:54 AM - edited 11-18-2020 02:51 AM
Reference files used in the Chalktalk
Debugs on the Foreign Controller
Debugs on the Anchor Controller
Cisco Unified Wireless Guest Access Services from the Enterprise Mobility 4.1 Design Guide
Wireless LAN Controller Web Authentication Configuration Example
Wired Guest Access using Cisco WLAN Controllers Configuration Example
[Q] How will the traffic flow if we want to use the auto-anchor feature not for guest access, but with Enterprise security and 802.1x authentication via Radius? Which part of the connection will be managed by the foreign and which part by the anchor controller?
[A] All the traffic up to the completion of the L2 authentication is managed by the foreign controller. This means that the communication with the Radius server is handled by the foreign controller itself: once the L2 authentication is completed, the rest of the client's traffic will be tunneled to the anchor controller.
Example: Debugs on the Foreign and Debugs on the Anchor
Thanks Federico for sharing this VoD and Doc's.
Vinay Sharma
Community Manager - Wireless
is possible to have redundancy anchor controller?
Yes, you can configure 2 anchors for the guest WLAN. The WLC will load balance the clients between the two anchors, and in if one fails, they will fall over to the other anchor.
Steve
Ok, I've already done. my question is how to be the priority rather than a anchro to another?
Andrea
Where did the video go!? There is only an image now, no embedded video..
