How do I install client adapter firmware to support LEAP ?
683
Core Issue
Installing client adapter firmware to support LEAP.
Resolution
The following error message
Cannot find a wireless adapter that supports LEAP. Please make sure that you have installed the correct client adapter and updated your firmware indicates that the LEAP authentication has failed because the client adapter's firmware does not support LEAP.
To resolve this issue, follow the instructions for installing the latest client adapter firmware.
Note: Try to upgrade the BIOS on the system and see if that works.
Problem Type
Install
Error message
Products
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
Content for Community-Ad
