How to configure protocol filtering
1040
Resolution
Protocol filters prevent or allow the use of specific protocols through the Access Point (AP). To configure protocol filters on your AP, perform the steps for the appropriate model AP you want to configure.
Note: Once a filter is created, it must be specifically enabled in the 350 and 1200 series APs, or applied in the 1100 and 1200 series APs. For directions on enabling and applying filters, refer to the instructions in the above-mentioned documents.
Problem Type
Configure / Configuration issues
Products
Access point
SW Features
Protocol filtering
Content for Community-Ad
