Introduction
How to download firmware and drivers for Cisco legacy 4800 wireless client cards
Resolution
To download the firmware and drivers for the Cisco legacy wireless cards, perform these steps:
- Browse to Downloads Home--> Products--> Wireless Downloads
- Select the version of Microsoft Windows in use to download the appropriate version from the list. The latest version is 5.02.20.
For more information, refer to these documents:
Note: The products listed in Product Bulletin, No. 1252 are no longer supported.
Troubleshooting the Client Adapter
This section provides troubleshooting tips should you encounter problems with your client adapter. Use Table 10-2 to quickly find specific troubleshooting information.
Table 10-2 Troubleshooting Information
Page Number
Using the troubleshooting utility | 10-3 |
Disabling the Microsoft Wireless Configuration Manager | 10-7 |
Disabling the Microsoft 802.1X supplicant | 10-8 |
Client adapter recognition problems | 10-8 |
Resolving resource conflicts | 10-8 |
Problems associating to an access point | 10-10 |
Problems connecting to the network | 10-10 |
Prioritizing network connections | 10-11 |
Parameters missing from Profile Management windows | 10-17 |
Windows Wireless Network Connection icon shows unavailable connection (Windows XP only) | 10-17 |
Problem Type
Download
Products
ACU (Aironet Client Utility)
AIR-LMC352
Reference
For more information on how to troubleshoot Cisco Aironet Wireless LAN client adapters, refer to the Troubleshooting the Client Adapter
section of Troubleshooting
