f-vanryckeghem
I have multiple AP-1242  ( in autonomous Mode) to manage on remote location ( more than One thousand ) . All of them have 2.4 Ghz Antenna 4941. Some of them have antenna 5135 ( Ghz) . Is the a way  ( except a visual inspection)  to  know if 5135 antenna's are connected to  an  AP with a show command ?
I  did not find anything on the net  about that.
Thanks a lot for you tips
Frédéric
Leo Laohoo
No.
muratg7777
Antennas are passive devices so you can not see which one is connected
But;
5135 use dot11radio1 interface. Check the interface is configured or not.
f-vanryckeghem
Indeed that  was my  fear  ...  but in  fact  radio  interface is  not configured because antenna's were placed "for future use" ... so only the visual inspection  may  help me  great :-(
thank  for your post ... you have confirmed what I  though
Frédéric
