I have multiple AP-1242 ( in autonomous Mode) to manage on remote location ( more than One thousand ) . All of them have 2.4 Ghz Antenna 4941. Some of them have antenna 5135 ( Ghz) . Is the a way ( except a visual inspection) to know if 5135 antenna's are connected to an AP with a show command ?
I did not find anything on the net about that.
Thanks a lot for you tips
Frédéric
