how to limit traffic by Qos on Wism / 1142AP
1148
HI
   I have few 1142n ap and register to wism (7.0.98.0)
   there are 9 ssid and 9 vlan on wism
   there is one ssid and vlan  for guest (open with no security policy)
   I use qos to limit traffic ( using qos profile brozne)
   per-user bandwidth contracts change to ...
   average data rate 128, burst data rate 128 , average real-time rate 128 , burst real-time rate 128,
   other no change
  than go WAN  edit guest  qos to bronze , wmm policy (allowed)
  It is limit guest (per client) download (download a file@ 128kbps-) ,
  but upload seems no limit (upload a file @70Mbps-)
  I need  limit guest per client both download and upload bandwidth @128kbps
  any suggestions are welcom
  thanks
Community Member
Hi ,
You posted a document not a question.  Please post this question in the Discussion area so that someone may help you.  I suggest you go back here:
https://supportforums.cisco.com/community/netpro/wireless-mobility/others?view=discussions
login and Start a discussion under the action menu.  Once you have submitted your question, you can delete this document.
Jithin
Cisco Support Community Moderator
Content for Community-Ad
August's Community Spotlight Awards
