Core Issue
Trying to locate the lastest version of firmware, drivers, and utilities for Aironet devices.
Resolution
To locate the latest firmware go to the Wireless LAN Cisco Downloads. Once there you will be able to locate your platform and locate the latest version of firmware, drivers, or utilities by looking at the numbering sequence.
Note: The Wireless Software Selector does NOT contain 350, 1300 and 1400 Wireless Bridge Software. This software can only be accessed if you have a Cisco.com login with a service agreement. The software is located in Option 2 Display Tables or in the Cisco IOS Upgrade Planner. If you are not a registered user, please go to Cisco.com registration.
Problem Type
Upgrade
Products
Workgroup bridges
Access point
Bridge
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
Base Station
