TCC_2
Level 10
Level 10
Introduction
How to reboot the access point
Resolution
You can restart the access point by one of the following methods
1.  Remove the power and replug the power cable
2.  Using the CLI in the ap prompt  type boot command. i.e  [ap:boot]
3.  In the Web interface use  the System Configuration Setup page to restart the access point. Use the System Configuration Setup page to restart the access point.
  • Click "Warm" Restart System Now to perform a warm restart of the access point. A warm restart reboots the access point.
  • Click "Cold" Restart System Now to perform a cold restart of the access point. A cold restart is the equivalent of removing and then reapplying power for the access point.
Action Buttons
Command
Description
Performs a warm restart of the device. A warm restart reboots the device.
Performs a cold restart of the device. A cold restart is the equivalent of removing and then reapplying power for the device.
Reset System Factory Defaults Except IP Identity
Click this button to reset all of the settings, except
  • The device's IP address, subnet mask, default gateway, and boot protocol
  • The users in the User Manager list
  • The SNMP Administrator Community name
Reset All System Factory DefaultsClick this button to return all settings to their factory defaults (including the IP identity) except:
Read Config File From Server
Click this button to send a configuration file from the server to the device.
Browser Update Now
Click this button to send the configuration file you named in the Additional System Configuration File entry field to the device.
Problem Type
Hardware issues
Reset defaults
Power / cable compliance
Products
Access point
Reference
Restarting the Access Point
Action Buttons
m.rana.ku
Three easy steps to Reset Cisco AP using MODE button:
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/eGCnTWBEpp8
Step 1: Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2: Press and hold the MODE button while you reconnect power to the access point.
Step 3: Hold the MODE button until the Status LED turns amber (approximately 10 to 12 seconds), and release the Button. All access point settings return to factory defaults.
