How to test the antenna alignment
1299
Resolution
Use the carrier test to determine the best frequency for the access point to use.  The carrier test helps you determine which radio frequencies contain the most radio activity and noise that could interfere with radio signals to and from the access point.
For steps on performing the antenna alignment test, refer to the Network Diagnostics Page section of Cisco Aironet 350 Series Diagnostics and Troubleshooting.
Problem Type
Analyze (examine, manage, test or view data)
Products
Access point
