How to use Authorization Profile for different WLAN SSID?
2565
    Introduction
    In this document, we will discuss scenario where user is "Trying to setup the two different authorization profiles for two different WLAN SSID users".
    But currently they found that since these two SSID users are all coming  from the same NAS (WLC) to the same ACS, it is very hard to let ACS tell the  different between them. These two profiles need to base on the SSID, but WLC does not send the SSID  with user's credential to ACS.
    Problem Description
    We have two valid users: user1, user2, they both may use SSID 1 and SSID  2 which is broadcasted in all areas. (area 1, Area 2, area 3)
    In area 1, only user1 allows to login SSID 1 and SSID 2.
    In area2, only user2 can login SSID1 and SSID2.
    In area 3 allows them all for SSID 1 and SSID2.
    Problem Category
    Wireless
    Problem Subcategory
    Cisco Wireless LAN Controller (WLAN)
    Cisco ACS (Access Control Server)
    Software
    WLC running 7.x
    ACS 4.x
    Hardware
    Wireless LAN - WLC-5500
    Solution
    WLC can send the SSID as part of the Called station ID attribute:
    (Cisco Controller) >config radius callStationIDtype ?
    ipaddr                       Sets Call Station Id Type to the system's IP Address
    macaddr                   Sets Call Station Id Type to the system's MAC Address
    ap-macaddr-only       Sets Call Station Id Type to the AP's MAC Address
    ap-macaddr-ssid       Sets Call Station Id Type to the format <AP MAC address>:<SSID>
    This can be used later in a NAR policy in ACS, with restrictions per user or group
    There is a documented config example here:
    Restrict WLAN Access based on SSID with WLC and Cisco Secure ACS Configuration Example
    Logs
    When user made the suggested changes in the configuration:  WLC radius callStationidType from ipaddr to ap-macaddr-ssid, the radius summary did not show the correct call station id type:
    The call station id type became undefined.
    Before
    (WLC-5500) >show radius summary
    Vendor Id Backward Compatibility................. Disabled
    Call Station Id Case............................. lower
    Call Station Id Type............................. IP Address
    Aggressive Failover.............................. Enabled
    Keywrap.......................................... Disabled
    After:
    (WLC-5500) config>radius callStationIdType ap-macaddr-ssid
    (WLC-5500) config>end
    After
    Call Station Id Type............................. Undefined
    More Information
    This is known bug, fixed on 7.0.116.0: CSCti02734 J-MR-Radius CallStationIdType show undefined for ap-macaddr-ssid
    Network Setup
    In this example setup, WLC is registered to the LAP. Two WLANs are used. One WLAN is for the Admin department users and the other WLAN is for the Sales department users. Wireless client A1 (Admin user) and S1 (Sales user) connect to the wireless network. You need to configure the WLC and the RADIUS server in such a way that the Admin user A1 is able to access only the WLAN Admin and is restricted access to the WLAN Sales and the Sales user S1 should be able to access the WLAN Sales and should have restricted access to the WLAN Admin. All users use LEAP authentication as a Layer 2 authentication method.
    Information on NAR
    Cisco Secure ACS supports two types of NAR filters:
    1. IP-based filters—IP-based NAR filters limit access based upon the IP addresses of the end-user client and the AAA client. Refer to About IP-based NAR Filters for more information on this type of NAR filter.
    2. Non-IP-based filters—Non-IP-based NAR filters limit access based upon simple string comparison of a value sent from the AAA client. The value can be the calling line ID (CLI) number, the Dialed Number Identification Service (DNIS) number, the MAC address, or other value that originates from the client. For this type of NAR to operate, the value in the NAR description must exactly match what is sent from the client, including whatever format is used. For example, (217) 555-4534 does not match 217-555-4534. Refer to About Non-IP-based NAR Filters for more information on this type of NAR filter.
    If you use RADIUS, the NAR fields listed here use these values:
    • AAA client—The NAS-IP-address (attribute 4) or, if NAS-IP-address does not exist, NAS-identifier (RADIUS attribute 32) is used.
    • Port—The NAS-port (attribute 5) or, if NAS-port does not exist, NAS-port-ID (attribute 87) is used.
    • CLI—The calling-station-ID (attribute 31) is used.
    • DNIS—The called-station-ID (attribute 30) is used.
    Refer to
    Network Access Restrictions
    for more information on the usage of NAR.Since the WLC sends in the DNIS attribute and the SSID name, you can create per-user SSID restrictions. In the case of the WLC, the NAR fields have these values:
    • AAA client—WLC IP address
    • port—*
    • CLI —*
    • DNIS—*ssidname
    Reference
    This document was generated from the following discussion: How to use authorization profile for different WLAN SSID?
    Content for Community-Ad
