TCC_2
Level 10
Level 10
Core Issue
Need assistance enabling Wired Equivalent Privacy (WEP) on third party devices.
Resolution
Cisco Aironet products can establish 40-bit Wired Equivalent Privacy (WEP) connections with IEEE 802.11b-compliant non-Cisco products. If you want to create a 128-bit WEP link, Cisco products only interact with other Cisco products.
If you are using a third-party device with a Cisco Aironet product, you must set both devices to use 40-bit WEP.
For configuring third party Access point , contact the respective vendor. For configuring  WEP on Cisco client adapters refer Entering a New Static WEP Key  section of  Configuring the Client Adapter
Problem Type
Configure / Configuration issues
Other vendors
Products
Other vendor adapters
Other vendor AP
