James.Muzyanda1
Community Member
Dear All,
I am trying to set up a Wireless Bridge between two locations using Cisco Bridge Aironet 1410 Series with Aironet Anttena 24dbi. The radio set at the main office is in Root mode and the site radio is non-root.
Root IP information:
IP: 192.168.3.20/24
radio encryption settings: TKIP
Client authenticated key manegement: mendatory with WPA pre-shared key
All these 2 radios have the same SSID.
The issue is that the non-root radio is unable to associate with the root radio, I am getting the error message: INTERFACE DOT11RADIO0 CANNOT ASSOCIATE RCVD RESPONSE FROM 003a.997c.b461 channel 161 15632 and sometimes I get the second error message "PACKET TO CLIENT 003a.997c.b461 REACHED MAX RETRIES REMOVING THE CLIENT
Can please assist me to solve this error message?????
James
I am also having a problem getting a bridge setup, and am seeing your first error
*Mar  1 00:21:27.011: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from 6cfa.8919.1840 channel 2 3103
were you able to solve the problem ?
NetadminTX
paulhesse1
Did this get answered I have the same issue -
*Mar 1 12:55:21.135: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 12:55:21.719: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 12:55:21.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 12:55:22.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 12:55:34.159: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response
*Mar 1 12:55:46.159: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from 6cfa.8918.12e0 channel 3 3240
*Mar 1 12:57:01.159: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Authenticating
*Mar 1 13:02:59.159: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Associating
