TCC_2
Level 10
Level 10
Resolution
A Cisco WGB device does not support multiple VLANs in it.  A 1100 AP, however, that acts in WBG mode can support multiple VLANs in it but with these restrictions:
  • The VLANs must be assigned on both the root AP and WGB sides. On WGB use the command workgroup-bridge client-vlan to configure the VLANs.  On WGB make sure you map each VLAN to an SSID same as the Root AP.
  • The WGB must be connected to a dot1Q-capable switch.
  • The WGB associates as an infrastructure device. The Infrastructure SSID must be mapped to the native VLAN on root and the WGB.
Here are some of relevant URLs
Problem Type
Release notes / product  overview / data sheet / FAQ
Technical product specification / features
Products
Access point
Workgroup bridges
SW Features
VLANs
