Is it possible to prevent the laptop roaming from the target AP to a different AP to find the extent of coverage?
916
Resolution
In order to check the extent of coverage before the laptop roams to an access point (AP) that is different from a target AP, try one of these options:
  • Temporarily change the service set identifier (SSID) either on the target AP or on the surrounding APs. You can also disable the radios of the surrounding APs when the site survey is performed. Apart from this, there is no way to restrict the client from roaming into another AP.
  • Add a test SSID on the target AP and remove it once the site survey is done. This brings down the interface on the target AP, but only for a short while when the new SSID is configured.
Problem Type
Release notes / product  overview / data sheet / FAQ
Technical product specification / features
Products
Access point
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
Content for Community-Ad
