TCC_2
Level 10
Level 10
Core Issue
Resolution
It is not possible to run static Wired Equivalent Privacy (WEP) keys for encryption and Extensible Authentication Protocol (EAP) for authentication in the same service set identifier (SSID). VxWorks allowed this configuration due to a software vulnerability. It was not a feature. What you can do is create two SSIDs and two VLANs (one per SSID) and configure open authentication with WEP for one SSID and EAP authentication for the other SSID.
For more information on Cisco Aironet Access Points (APs), refer to Cisco Aironet Access Point FAQ.
Problem Type
Release notes / product  overview / data sheet / FAQ
Technical product specification / features
Products
Access point
Security Options
EAP
WEP key
Product OS
IOS
