12-02-2020 01:19 PM - edited 11-22-2023 12:03 PM
Problem Description:
Due to the certificate expiration, any new Control and Provisioning of Wireless Access Points (CAPWAP) or Light Weight Access Point Protocol (LWAPP) connection will fail to establish. The main feature that is affected will be the Access Point (AP)-to-controller joining. The secondary feature that is affected will be new mobility connections between the controllers.
When an AP attempts to establish a new connection, the AP fails to join. When you configure mobility between controllers, they will fail to establish a connection.
The likelihood that this issue will be encountered is 100% for wireless products in use (to include APs and controllers) that have a Manufacturer Installed Certificate (MIC) that is older than ten years. Self-Signed Certificates (SSCs) that were generated by the Autonomous-to-lightweight Upgrade Tool will expire on January 1, 2020.
The affected products (listed in the Products Affected section) were released prior to the end of CY2005; beginning in March 2015, the products might begin to experience these symptoms.
Some Cisco CAPWAP based wireless solutions are reaching an age of 10 years from the date of manufacture. When this occurs CAPWAP DTLS tunnels will fail to be established because the certificates on CAPWAP based hardware has expired. The certificate installed in the wireless hardware is used to authenticate the devices when joining the network.
This issue is being tracked via Cisco defect ID: CSCuq19142 and via Field Notice 63942.
*Note: The MIC Lifetime has been documented in past via the Wireless LAN Controller (WLC) Design and Features FAQ at http://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/118833-wlc-design-ftrs-faq.html.
Problem Symptom:
Wireless Access Points fail to connect to the Wireless LAN Controller. At the time of the join failure, the WLC's msglog may show messages similar to the following:
Jul 10 16:13:52.443 spam_lrad.c:6164 LWAPP-3-PAYLOAD_ERR: Join request does not contain valid certificate in certificate payload - AP 00:11:22:33:44:55
CAPWAP utilizes Datagram Transport Layer Security (DTLS) in order to encrypt communication between the Lightweight AP and the WLC. The MIC or SSC is used in order to authenticate the Lightweight AP to the WLC, and vice versa, during the DTLS session establishment. The CAPWAP/DTLS connection cannot be established after the MIC or SSC validity end date.
Affected Products:
Date |
2006 Series Wireless LAN Controller |
4.2.x |
24/Mar/05 |
02/Apr/07 |
21/Apr/12 |
NM-AIR-WLC6 |
4.2.x |
27/Feb/06 |
18/Feb/08 |
16/Feb/13 |
NME-AIR-WLCx (Cisco Wireless LAN Controller Module (WLCM)) |
7.0.x |
15/Feb/07 |
23/Apr/12 |
30/Apr/17 |
AIR-CT2504 |
8.5.x |
8/Jul/11 |
18/Apr/18 |
30/Apr/23 |
AIR-CT5508 |
8.5.x |
6/May/09 |
4/May/18 |
31/Jul/23 |
AIR-CT7510 |
8.5.x |
25/Mar/11 |
10/Apr/17 |
30/Apr/22 |
AIR-CT8510 |
8.5.x |
30/Aug/12 |
3/Sep/18 |
30/Sep/23 |
WS-SVC-WISM2 |
8.5.x |
2/Apr/11 |
10/Apr/17 |
30/Apr/22 |
Cisco Aironet Branded Lightweight Access Points - FCS in 2010 or earlier:
Family / SW Type |
Last Software Release |
FCS Date |
End Of Sale Date |
Last date of Support (HW) |
End of Sale Notice |
Cisco AP801 Integrated Access Point |
8.0.x |
26-Jun-08 (CISCO888W-GN-A-K9) |
31/Mar/16 (C887VA-V-W-E-K9) |
31/Mar/21 |
Cisco Aironet 1000 Series |
4.2.x |
24/Mar/05 |
11/Mar/08 |
10/Mar/13 |
Cisco Aironet 1040 Series |
8.3.x |
24/Aug/10 |
1/Oct/13 |
30/Sep/18 |
Cisco Aironet 1120 Series |
7.0.x |
02/Oct/02* |
19/Jun/09 |
18/Jun/14 |
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1100-series/eol_c51-506612.html |
Cisco Aironet 1130 Series |
8.0.x |
24/Nov/04* |
26/Jul/13 |
31/Jul/18 |
Cisco Aironet 1140 Series |
8.3.x |
30/Sep/09 |
1/Oct/13 |
30/Sep/18 |
Cisco Aironet 1200/1230 Series |
7.0.x |
23/Aug/02* |
19/Jun/09 |
30/Jun/14 |
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1230-ag-series/eol_c51-506614.html |
Cisco Aironet 1240 Series |
8.0.x |
12/Dec/05 |
26/Jul/13 |
31/Jul/18 |
Cisco Aironet 1250 Series |
8.0.x |
02/Nov/07 |
20/Jan/12 |
31/Jan/17 |
Cisco Aironet 1260 Series |
8.3.x |
27/Apr/10 |
7/Oct/13 |
2/Jan/18 |
Cisco Aironet 1300 Series |
7.0.x |
04/May/04* |
11/Jan/13 |
31/Jan/18 |
Cisco Aironet 1600 Series |
8.5.x |
16/Nov/12 |
29/Dec/16 |
31/Dec/21 |
Cisco Aironet 1700 Series |
8.10.x |
01/Jun/14 |
30/Apr/19 |
30/Apr/24 |
https://www.cisco.com/c/en/us/products/collateral/wireless/eos-eol-notice-c51-740712.html |
Cisco Aironet 2600 Series |
8.5.x |
18/Jun/12 |
29/Dec/16 |
31/Dec/21 |
Cisco Aironet 2700 Series |
8.10.x |
21/Mar/14 |
30/Apr/19 |
30/Apr/24 | https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2700-series-access-point/eos-eol-notice-c51-740711.html |
Cisco Aironet 3500 series |
8.5.x |
26/May/10 |
1/Apr/16 |
31/Mar/21 |
Cisco Aironet 3600 series |
8.5.x |
20/Oct/11 |
29/Dec/16 |
31/Dec/21 |
Cisco Aironet 3700 Series |
8.10.x |
02/Sep/13 |
30/Apr/19 |
30/Apr/24 |
Cisco Aironet AIR-CAP1552I series |
8.5.x |
2/May/11 |
30/Mar/16 |
31/Mar/21 |
Cisco Aironet 1570 series: AIR-AP1572EAC and AIR-AP1572EC |
1/Sep/14 |
13/Nov/20 |
30/Nov/25 |
Cisco Aironet 1570 series: AIR-AP1572EC3, AIR-AP1572EC4, AIR-AP1572IC3 and AIR-AP1572IC4 |
1/Sep/14 |
30/Apr/19 |
30/Apr/24 |
*Note: For AP series whose FCS date is before 2005: APs started being manufactured with MICs on July 18, 2005. Any Lightweight AP's that were manufactured prior to that date have SSCs.
Workaround prior to the fix being available:
If you believe you will be affected by this issue and need a fix before the official code with the associated correction is posted at www.cisco.com, then please contact TAC, who will work to provide an escalation release of code accordingly.
Recovery for APs in a failed scenario:
*Note: This workaround should only be used in order to allow APs with expired certificates to join the WLC for long enough to upgrade the software.
If the certificates have expired, disable NTP, then change the WLC clock time to a recent earlier time when the certificates were still valid. If you set the clock back too far, newer APs may not be able to join. Once the software has been upgraded, and the affected APs have joined, the WLC clock should be reset to the valid time.
*Note: Temporarily disabling NTP and changing the WLC's time settings can adversely affect other time dependent WLC features such as MFP, SNMPv3, and location.
Solution:
To allow additional usage of hardware, beyond the 10 year certificate date, Cisco is providing a software maintenance release with a feature to ignore the validity period of the certificates in the CAPWAP authentication process.
Maintenance releases with the feature to ignore the validity period of the certificates are being created for AireOS 7.0, 7.4 and 8.0.
Cisco has released the fix to Cisco.com in AireOS 7.0.252.0 and 7.4.140.0
Cisco will release to Cisco.com a rebuild of AireOS 8.0 (as version 8.0.120.0) before July 2015.
*Note: Cisco has a beta version of AirOS 8.0 MR2 that does contain the needed commands to work around this issue and can be used until the official AireOS 8.0 MR2 (8.0.120.0) is released on Cisco.com, see the following URL for details:
https://supportforums.cisco.com/document/12492986/80mr2-beta-availability
These maintenance releases should be updated before the certificate expires on the APs and WLCs.
By default, if an AP and/or WLC certificate has expired, then the DTLS connection will fail. To allow AP's to join a WLC after certificate expiration, upgrade to the fixed software version, then use the following commands:
For 7.0.252.0:
(WLC)>config ap lifetime-check {mic|ssc} enable
For 7.4.140.0 and later:
(WLC)>config ap cert-expiry-ignore {mic|ssc} enable
With "config ap lifetime-check {mic|ssc} enable" or "config ap cert-expiry-ignore {mic|ssc} enable" in effect, the WLC and AP will ignore the expiration date on the devices' MICs and SSCs. The above-noted commands must remain in effect as long as devices with expired MIC or SSC certificates are used.
Because 4400 series WLCs that were among the first manufactured had both Airespace and Cisco MICs installed, with the Airespace MIC being given precedence by the WLC, and the fix for CSCuq19142 is only applicable for Cisco MICs,the currently available fix for CSCuq19142 may not work. This is potentially applicable to most 4400s manufactured in 2005, and other variants, depending on RMA and refurbishment history of the affected unit. Please see section "How to Identify Hardware Levels" for how to determine the date of manufacture. If the affected unit was refurbished, the SN may have changed with the MIC remaining the same. At present the only remedy is to disable NTP, then change the WLC clock time to a recent earlier time when the certificates were still valid. Contact TAC to get an escalation image with the fix, as per bug ID CSCuu02970.
How to Identify Certificate Expiration date:
(via CLI or Serial number or Python Script or WLCCA)
This section describes how to determine when your AP and WLC MICs and/or SSCs expire using show commands when available or via the device serial number.
1) Manufacturing Installed Certificates (MICs):
The serial number can be used to determine the approximate date when the MIC will expire.
The AP's MIC will expire, at the earliest, ten years past the date of manufacture. Please note, some APs may have more recently created MICs under some conditions. For example, if the AP's motherboard was manufactured and stored, but not assembled until some time later or if the AP was subject to RMA and a refurbishing process, etc.
To determine when the AP was manufactured, run this command on the WLC to find the AP SN:
(Cisco Controller) >show ap inventory all
Inventory for lap1130-sw3-9
NAME: "Cisco AP" , DESCR: "Cisco Wireless Access Point"
PID: AIR-LAP1131AG-E-K9, VID: V01, SN: FCZ1128Q0PE
NAME: "Dot11Radio0" , DESCR: "802.11G Radio"
PID: UNKNOWN, VID: , SN: GAM112706LC
NAME: "Dot11Radio1" , DESCR: "802.11A Radio"
PID: UNKNOWN, VID: , SN: ALP112706LC
The AP chassis SN is in the first section of the output, for example: PID:
See "Deriving manufactured date from serial number" section below.
Alternatively, the exact date the MIC expires can be found by running this command and looking for the "Certificate" entry; ignore "CA Certificate" entries. The "end date" associated with the "Validity Date" section is the expiration date for the MIC certificate:
AP_CLI#sh crypto pki certificates
CA Certificate
Status: Available...
Certificate
Status: Available
Certificate Serial Number: 728AF4350000001E4C89
Certificate Usage: General Purpose
Issuer:
cn=Cisco Manufacturing CA
o=Cisco Systems
Subject:
ea=support@cisco.com
cn=C1130-001c58b5b3a4
o=Cisco Systems
l=San Jose
st=California
c=US
CRL Distribution Points:
http://www.cisco.com/security/crl/cmca.crl
Validity Date:
start date: 04:22:10 UTC Jul 11 2007
end date: 04:32:10 UTC Jul 11 2017
Associated Trustpoints: Cisco_IOS_MIC_cert
2) Self-Signed Certificates (SSCs):
In order to determine if you have an SSC, run this WLC command:
AP_CLI >show auth-list
AP with Self-Signed Certificate................ yes
All AP SSC's have an expiration date of January 1st, 2020.
3) Wireless LAN Controllers (WLCs):
You can determine the WLC's serial number by running this command:
WLC_CLI>show inventory
Burned-in MAC Address............................ 24:E9:B3:43:C4:E0
Maximum number of APs supported.................. 75
NAME: "Chassis" , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9, VID: V04, SN: PSZ17441ANT
To determine the WLC serial number via the GUI, navigate: Controller > Inventory
If you have AireOS 8.0 or later, to determine when the WLC certificate expires, run this command and look for the "Cisco SHA1 device cert":
WLC_CLI: show certificate all
Certificate Name: Cisco SHA1 device cert
Subject Name :
C=US, ST=California, L=San Jose, O=Cisco Systems, CN=AIR-CT2504-K9-d0c282d65a20, MAILTO=support@cisco.com
Issuer Name :
O=Cisco Systems, CN=Cisco Manufacturing CA
Serial Number :
454384735992863371807890
Validity :
Start : 2011 Jul 26th, 20:17:17 GMT
End : 2021 Jul 26th, 20:27:17 GMT
Signature Algorithm :
rsa-pkcs1-sha1
Hash key :
SHA1 Fingerprint : 98:89:eb:12:2a:98:bc:fe:ad:5b:8f:23:63:0f:47:d1:36:ce:f5:be
MD5 Fingerprint : ba:f3:98:9a:cd:f8:01:08:84:b8:66:3c:6a:6c:d3:05
This command is not available in AireOS releases prior to 8.0. There is no similarly straightforward command to derive this date in earlier AireOS releases. As an alternate method, use the WLC serial numbers to determine the earliest possible MIC expiration date.
Deriving manufactured date from product serial numbers:
The serial number format is: "LLLYYWWSSSS"; where "YY" is the year of manufacture and "WW" is the week of manufacture. The date code can be found in the 4 middle digits of the serial number.
Manufacturing Year Codes:
01 = 1997 06 = 2002 11 = 2007 16 = 2012
02 = 1998 07 = 2003 12 = 2008 17 = 2013
03 = 1999 08 = 2004 13 = 2009 18 = 2014
04 = 2000 09 = 2005 14 = 2010
05 = 2001 10 = 2006 15 = 2011
Manufacturing Week Codes:
01-05 = January, 15-18 = April, 28-31 = July, 41-44 = October
06-09 = February, 19-22 = May, 32-35 = August, 45-48 = November
10-14 = March, 23-27 = June, 36-40 = September, 49-52 = December
Example: SN FCZ1128Q0PE has year code 11, meaning it was manufactured in the year 2007. The week code is 28, meaning it was manufactured in July of that year.
4) Access Point Certificate Check Tool:
A Python script has been written that runs on Windows, Mac and Linux systems that allows a user to check on the certificate expiration date for all AP's on their network.
The following Cisco Support Forum's article explains how to access and run this tool:
Access Point Certificate Check Tool - apCertCheck
5) Wireless LAN Controller (WLC) Config Analyzer:
WLCCA version 3.6.5 and above has support to check the AP Certificate expiration date. This check is done based on the AP Serial number and will flag any AP needing checked based on if the AP serial number is within 60 days of expiration.
NOTE: Using the AP Serial number is only an approximation of the MIC expiration date. Any AP's flagged by this method should always be check for the real MIC expiration date via the Access Point commands listed.
Hi Cisco Team,
Hope you're doing well.
We have the same issue but this is only happens when our connection failover from ISP 1 to ISP 2. Is it ISP issue? Please help us to solve this issue, were trying to trouble shoot since last year :(
Hi Timsmith, thanks for sharing
is it possible this is only happens during fail over? Example we have ISP 1 and ISP 2, when using the ISP 1 we did not encountered this certificate expiration but if we do the fail over the ISP 2 we see this issue. All AP's are disconnected to WLC but the WLC can ping the access points. Thank you very much
When running the Cisco CLI Anayzer, is there a way to check which AP's have a cert issues based on this bug CSCvi48253.
For 7.0.252.0:
I am getting an Error when I try to use this command on a 5760 WLC
WAC_5700_CAB#config ap lifetime-check mic enable
% Invalid input detected at '^' marker.
WAC_5700_CAB#
WAC_5700_CAB#config ap cert-expiry-ignore mic enable
WAC_5700_CAB#
I am experiencing the same problem with WLC 5760 and AIR-LAP1142M-E-K9
WLC:
Software Version | 03.06.10E RELEASE SOFTWARE (fc2) |
%PKI-3-CERTIFICATE_INVALID_EXPIRED: Certificate chain validation has failed. The certificate (SN: 41D19569000000232FB9) has expired.
when I return date to 2018 AP join again.
So this bug isn't resolved in new versions???
Is there a way to see if this process has been done already?
Got an AP which is not able to join to WLC2 but to WLC1 <-- both have the same time settings.
As this works, i assume someone has already done this, but I would like to verify.
I had to have Cisco Tac help me set up self signed certificate and not use the mic certificate in the controller of the new 9800 to move these 3702's over to the new controller because the IOS on the 5700 and 3702s was too old.
I am using 5520 and 5508 WLC.
AP is using 1100 series and 2700,2800 series.
WLC's SHA1 device cert is valid for 22 years and 23 years.
Can certificate problems be prevented in advance by just using the "config ap cert-expiry-ignore {mic | ssc} enable" command??
I'm currently having this issue and I'm wondering if executing "config ap cert-expiry-ignore mic enable" will cause our 5508 controller to reload? Or do I have to reload the 5508 in order for the new config to work properly? Additionally I'm wondering what happens to AP:s currently regeistered, will their CAPWAP sessions be resetted once I execute the CMD causing them to re-join the WLC?
@Tob when I did it nothing broke up or had to reboot.
Seconds after I pressed enter old APs came online, that's it.
An all people factor me to a few steerage on the way to limit SSH get right of entry to to the ISE nodes from a choose range of depended on networks? While the WebGUI scriptlike thiscan be configured to restriction get entry to I can not see a way to without problems limit SSH other setting a firewall inline?
all cisco devices that uses certifices will fail. at one point. probem is with how cisco encodes 3ed part certifices in there software, there is only one perment fix ok maybe two, first option is build a certifice rule to by pass dates
most contolers will not bypass certifices useing above method, i know 6 months i work on this, my controler wont alow bypass of dates for one reason its used as athencation wich worthless with bad certific. so how do you get around this,
one you replace the software and if u have no contrack then u are screwed, u can back date controler but note then will not athencate with radius as it must have same time set, there is a way cisco can recode the software not ueing certifices at all and even more secure then useing them, we was ack working on this when cisco close cass ios still has probems pass down from each gen of ios will cause ios to crash i know i had 5 versions of software each has same probems , but cisco did not want know what i discover, list commands that worthless, note newest ios has commands that not even cisco knows about that just floor me, the last fix was to incode in software to disable this kind athencation as cisco has no clue how fix it, but it easy fix, in fack cisco miss lot probems and i dont get how so many probems could lie in the software,
but to each probem on some swichs work arounds, but more imported then fix is u must have the mib files, these files usens smnp to try recode the ios so will work , with out these files makes much harder run, cisco dose not like working people dont have contracks even if they can fix this probem, HAY CISCO I KNOW HOW FIX THIS PROBEM
but key quistion is what do i want for it , 20 years ago cisco alow me replace warrenty hardware even throw i pass not one test even thow i never went to school why because i could do it to me it was easy ibm hp all did same, microsoft used me for 25 years to help fix there probems but they never could grasp what real probem was, or is,
cisco probem can be fix by useing anouther form of security, and drop the certifices all to gather,
on the swich unnder crypro on some swichs u can code the swich to bypass dates on certifces
but each must be match to a rule in shout it about 40 lines of code, but u have know information about the certifices
so how do u get this information go to ap list certifices loaded key information there, look for out dated certifices
probem there, but on controler as well, u can copy ap certifices to the controler all of them that dose not code the ipaddress of unit or ap name. these not ones used for athencation any way, there is a
securty warrning i will give, when u load the contorler in to web broser and copy the certifice for some reason idk why
these certifices are coded to bypass all security on pc. if i was any one i edit use of these certifices to athencation only
and for encitpion of ip all others should be uncheck now why was this done idk but i tell you if some one got the same certifice they log in to a pc,, i warn cisco of these probems this is key reason why rasomware is installed these kinds certifices to by pass securty so rasomware hurts ways to get around the securty,
as far tac helping you you have better chance talking to god, only in extramly rare cases will they help u
in over 40 phone calls only one just one did they help me replace software on bouth the siwch and controler as bouth keep crashing do to what ios codeing probems , some commands even in new software will cause software to crash,
i go throw list with cisco to fix each every probem but no they close the case, they had do nothing but one thing as i gave them the bugs if ios give me update to retest . so cisco dose not want to fix these probems for you if you dont have contrack good luck becuase u will so need it what will help is crash reports these can get you new software
but only if shows certen erros , as to rest cisco will never ever fix this probem they dont know how to , when software and hardware was all move to china much of information was lost at best we got people who are want a be went to school but has no hands on expeace with them so they pull up information as they dont know anything , if not in there servers they dont know, and i find very few people that knows anything , in fack why hasent cisco fix the probem instead they just turn off this kind athencation now any wifi that can join will do so even if u dont want it to ,
wow what a fix
