Gilles Dufour
Topology
picture from http://lteworld.org/blog/lcs-architecture-lte-eps
ASR5x00 MME Configuration
  context SGSN_MME
    mme-service mme
      mme-id group-id 32768 mme-code 105
      plmn-id mcc MMM mnc NN
      associate egtp-service mme-egtp-s10s11 context SGSN_MME
      associate hss-peer-service HSS context HSS
      associate sgtpc-service sgtp-mme context SGSN_MME
      associate sgs-service SGs context SGs
      associate location-service SLG_SLS
  context HSS
    interface sls-27/1-vlan704
      ip address 10.6.1.60 255.255.255.248
    #exit
    interface sls-lb1 loopback
      ip address 10.6.0.1 255.255.255.255
    #exit
    interface sls-lb2 loopback
      ip address 10.6.0.2 255.255.255.255
      associate diameter endpoint SLg
      associate sls-service egmlc
    exit
    sls-service egmlc
      esmlc esmlc-id 1 ipv4-address 10.200.6.30 ipv4-address 10.200.6.11 port 2905 weight 1
      bind ipv4-address 10.16.0.1 ipv4-address 10.6.0.2 port 9082 sctp-template SLs
    #exit
      origin realm cisco.com
      use-proxy
      origin host MMEXXX.MMEXXX.MME.EPC.MNC0NN.MCCMMM.3GPPNETWORK.ORG address 10.6.0.4 port 3868 address 10.6.0.5
      destination-host-avp always
      peer diameter.ciscowireless.com realm ciscowireless.com address 10.200.6.9 port 2906 sctp
      route-entry peer diameter.ciscowireless.com
      route-entry realm ciscowireless.com peer diameter.ciscowireless.com
      associate sctp-parameters-template SLg
Troubleshooting
Flow Chart
Monitor Subscriber
To understand messages exchanged for LCS, use monitor subscriber with following options (Diameter, S1AP, SLs)
First we receive the SLg Location Request in a diameter message.
+ in 09:20:53:572 Diameter 0x80000c (8388620) Provide-Location-Request
Diameter message from 10.200.6.9:2906 to 10.6.0.4:3868
Base Header Information:
Version: 0x01 (1)
Message Length: 0x0001c0 (448)
Command Flags: 0xc0 (192) REQ PXY
Command Code: 0x80000c (8388620) Provide-Location-Request
MME triggers S1 Paging
+ out 09:20:53:573 S1AP PAGING (10)
UE responds and MME sends Sls request.
+ in 09:20:53:921 S1AP INITIAL UE MESSAGE (12)
+ out 09:20:53:921 SLS Procedure Code: LOCATION SERVICE REQUEST (0)
SLS Tx PDU, from 10.6.0.1:9082 to 10.200.6.30:2905 (71)
SLs-AP (71 bytes)
Choice Index : Initiating Message (1)
Criticality : reject (0)
LOCATION SERVICE REQUEST value:
IEs Count : 9
IE : 0
Protocol IE ID : CORRELATION_ID (2)
CORRELATION_ID Value:
52428800 (0x3200000)
IE : 1
Protocol IE ID : LOCATION_TYPE (13)
LOCATION_TYPE Value:
Geographic-Information (0)
IE : 2
Protocol IE ID : E_UTRAN_CELL_IDENTIFIER (4)
Criticality : ignore (1)
E_UTRAN_CELL_IDENTIFIER Value:
PLMN Identity
0xNNMMM
Cell Identity
265986 (0x40f02)
IE : 3
Protocol IE ID : LCS_CLIENT_TYPE (8)
LCS_CLIENT_TYPE Value:
Lawful-Intercept-Services (3)
IE : 4
Protocol IE ID : LCS_PRIORITY (9)
LCS_PRIORITY Value:
Highest-Priority (0)
IE : 5
Protocol IE ID : LCS_QOS (10)
LCS_QOS Value:
Horizontal Accuracy
Vertical Requested
Vertical Coordinate Is Requested (1)
Response Time
Delay-Tolerant (1)
IE : 6
Protocol IE ID : UE_POSITIONING_CAPABILITY (20)
UE_POSITIONING_CAPABILITY Value:
TRUE (1)
IE : 7
Protocol IE ID : INCLUDE_VELOCITY (5)
INCLUDE_VELOCITY Value:
Not-Requested (1)
IE : 8
Protocol IE ID : IMSI (7)
IMSI Value:
XXXXXX09516386f4
End-to-end SLs communication through MME.
+ in 09:20:53:930 SLS Procedure Code: CONNECTION ORIENTED INFORMATION TRANSFER (1)
+ out 09:20:53:930 S1AP DOWNLINK UE ASSOCIATED LPPA TRANSPORT (44)
+ in 09:20:53:964 S1AP INITIAL CONTEXT SETUP (9)
+ in 09:20:54:201 S1AP UPLINK UE ASSOCIATED LPPA TRANSPORT (45)
+ out 09:20:54:201 SLS Procedure Code: CONNECTION ORIENTED INFORMATION TRANSFER (1)
After that we should respond to SLg diameter request.
Or if We timeout, we could see an abort.
+ out 09:23:19:833 SLS Procedure Code: LOCATION ABORT (3)
+ out 09:23:19:834 Diameter 0x80000c (8388620) Provide-Location-Answer Data: DIAMETER_ERROR_POSITIONING_FAILED (4225)
Show commands
Peer information
 ******** show sls-service peers all *******
Monday October 10 12:01:27 AST 2016
Total ESMLC:1
MM ESMLC-ID  AssocStatus  Uptime      Peer-ID     IP-Addresses-1[state]                         IP-address-2[state]
08 1         UP           10h48m29s   1xxxxxxx0   10.200.6.30[UP]                            10.200.6.11[DOWN]
SLS Service status
******** show sls-service all *******
Service name                         : egmlc
Service id                           : 12
Context                              : HSS
Status                               : STARTED
Bind                                 : Done
SLs-MME IP Address                   : 10.6.0.1
                                       10.6.0.2
SCTP Port                            : 9082
T-3x01 (Low Delay)                   : 20 s
T-3x01 (Delay Tolerant)              : 20 s
T-3x02                               : 3 s
Max Re-Transmission                  : reset (0)
SCTP Param Template Associated       : SLs
SCTP Alpha                           : 12
SCTP Beta                            : 25
SCTP Checksum Type                   : CRC32
SCTP Valid Cookie Lifetime           : 60000ms
SCTP Max Assoc Retrans               : 8
SCTP Max Number of In Streams        : 16
SCTP Init Retransmissions            : 8
SCTP Max MTU                         : 1428bytes
SCTP Max Number of Out Streams       : 16
SCTP Path Retransmissions            : 4
SCTP Min MTU                         : 1428bytes
SCTP RTO Initial                     : 200ms
SCTP RTO Max                         : 500ms
SCTP RTO Min                         : 150ms
SCTP Sack Frequency                  : 1
SCTP Sack Period                     : 10ms
SCTP Start MTU                       : 1428bytes
SCTP Heartbeat Status                : Enabled
SCTP HeartBeat Timer                 : 1s
SCTP Bundle Status                   : Enabled
SCTP Bundle Timer                    : 100ms
SCTP Alternate Accept Flag           : Enabled
SLS Service stats
******** show sls-service statistics *******
SLS-AP Statistics:
    Sent Messages:
         Location Request:          633           Location Abort:          126
         Connection Info:           8351           Connectionless Info:     0
         Reset Req:                 0           Reset Ack:               0
    Recevied Messages:
         Location Response:         508           Connection Info:         8792
         Connectionless Info:       0           Reset Req:               0
         Reset Ack:                 0
SCTP Statistics:
  Transmitted SCTP Data:
    Init Chunks:                      218  Init Ack Chunks:                    0
    Shutdown Chunks:                    0  Shutdown Ack Chunks:               36
    Cookie Chunks:                     58  Cookie Ack Chunks:                  0
    Data Chunks:                     9120  Data Ack Chunks:                 9436
    Shutdown Complete Chunks:           0  Heartbeat Chunks:            13644384
    HeartBeat Ack Chunks:        11610193  Abort Chunks:                      55
    Error Chunks:                       0
  Received SCTP Data:
    Init Chunks:                        0  Init Ack Chunks:                   58
    Shutdown Chunks:                   36  Shutdown Ack Chunks:                0
    Cookie Chunks:                      0  Cookie Ack Chunks:                 40
    Data Chunks:                     9436  Data Ack Chunks:                 8747
    Shutdown Complete Chunks:          36  Heartbeat Chunks:            11610193
    HeartBeat Ack Chunks:         4273331  Abort Chunks:                     158
    Error Chunks:                       0
  Retransmitted SCTP Data:
    Init Chunks:                       32  Shutdown Chunks:                    0
    Shutdown Ack Chunks:                0  Cookie Chunks:                    144
    Data Chunks:                      562
  Total Bytes Sent:               1215159  Total Bytes Received:          737483
  Total Packets Sent:                9120  Total Packets Received:          9436
Debug logs
2016-Oct-12+11:43:35.438 [sls 206303 debug] [5/0/6766 <sessmgr:110> sls_app_msg.c:230] [software internal user syslog] Sent SLS message
2016-Oct-12+11:43:35.438 [sls 206303 debug] [5/0/6766 <sessmgr:110> sls_app_msg.c:156] [software internal user syslog] Starting location response timer (40 seconds)
2016-Oct-12+11:43:35.448 [sls 206301 debug] [5/0/6766 <sessmgr:110> sls_app_msg.c:417] [callid 209afa9d] [software internal user inbound protocol-log syslog] SLS Rx PDU, from 10.200.6.30:2905 to 10.6.0.1:9082 (69)
2016-Oct-12+11:43:35.556 [sls 206302 debug] [5/0/6766 <sessmgr:110> sls_app_msg.c:227] [callid 209afa9d] [software internal user outbound protocol-log syslog] SLS Tx PDU, from 10.6.0.1:9082 to 10.200.6.30:2905 (209)
2016-Oct-12+11:43:51.876 [sls 206303 debug] [5/0/6766 <sessmgr:110> sls_app_utils.c:149] [software internal user syslog] Deleted SLS request. Correlation id : 115343363
2016-Oct-12+11:43:57.965 [sls 206305 info] [5/0/6766 <sessmgr:110> sls_app_msg.c:379] [software internal user syslog] Received SLs message(1) with invalid correlation id (115343363)
