Mobility Services Engine (MSE) platform status check up not working
9118
    Introduction
    Question
    User has installed MSE on a Virtual Machine (Windows 2003 Server) and facing issues.
    Getting Error while checking the state:-
    etc/init.d/msed status
    It loads a little and then shows Error:-
    Starting MSE Platform, Waiting to check the Status
    like 10 times and then an error comes up: "Failed to get the Status"
    This Error comes when:-
    • Restart
    • Shutdown
    • Configure and Save the configuration
    • Executing getserverinfo command
    The username and password hs been changed in order to associate it with WCS but when i go into the WCS and try to set it up, it says that there is an error in the username/password whereas i am using the same previously configured information in the MSE.
    WCS version is 6.0 but not sure about MSE version since it doesn't show it due to the error on the status.
    Answer
    User deleted the Virtual Machine where he had that MSE and downloaded the new MSE v7 as a VM workstation and now works perfectly.
    Question
    How to configure RF Tags? If we have AP 1131-N-K9, why can't we use its 802.11a RF? When I do a show run it says its interface is down and I can bring it up because it mentions an error about not being compatible with a Regulatory Domain.
    Answer
    We have similar issues with certain AP that the a radio show down although it is admin enabled. Check on your AP if that a radio is admin disabled then you might have to enable it.
    Question
    Similar Issue with MSE 7.4.100 on hardware platform.
    [root@MSE ~]# /etc/init.d/msed status
    STATUS:
    Health Monitor is running
    Starting MSE Platform, Waiting to check the status.
    MSE stops successfully, but doesn't start
    [root@MSE ~]# /etc/init.d/msed restart
    Stopping MSE Platform
    .......................Flushing firewall rules: [  OK  ]
    Setting chains to policy ACCEPT: nat filter [  OK  ]
    Unloading iptables modules: [  OK  ]
    Setting chains to policy ACCEPT: filter [  OK  ]
    Starting Health Monitor, Waiting to check the status.
    Health Monitor successfully started
    Starting Admin process...
    Started Admin process.
    Database started successfully. Starting framework and services ...
    Database started successfully. Starting framework and services ..........................
    Answer
    If the MSE is virtual then make sure that the resources are there that is required. Many time when we mess around with lab MSE this happens and usually a restart of the VM host fixes it. A few times it was basically me bringing up a new VM or reverting back to a snapshot that worked.
    Verifying the Mobility Services Engine Software State
    You can verify the mobility services engine software state at any time. In the mobility services engine CLI interface, enter: /etc/init.d/msed status
    If the mobility services engine is running, the command output looks like this example:
    Server Config
    Product name: Cisco Mobility Service Engine
    Version: x.x.x.x
    Hw Version: none
    Hw Product Identifier: none
    Hw Serial Number: none
    Use HTTPS: true
    HTTPS Port: 443
    Use HTTP: false
    HTTP Port: 80
    Legacy HTTPS: false
    Legacy Port: 8001
    Session timeout in mins: 30
    DB backup in days: 0
    Server Monitor
    Start time: Wed Sept 30 15:24:36 EDT 2008
    Server current time: Fri May 30 19:08:15 EDT 2008
    Server timezone: America/New_York
    Server timezone offset: -18000000
    Service Engine (1):
    VERSION: x.x.x.x
    Location Service Monitor
    Log Modules: 262143
    Log Level: INFO
    Days to keep events: 2
    Keep absent data in mins: 1440
    Restarts: 1
    Used Memory (bytes): 129851856 Allocated Memory (bytes): 3087007744
    Max Memory (bytes): 3087007744
    DB virtual memory (kbytes): 0
    DB virtual memory limit (bytes): 256000000
    DB disk memory (bytes): 4128768
    DB free size (kbytes): 2856
    Active Elements: 0
    Active Clients: 0
    Active Tags: 0
    Active Rogues: 0
    Active Elements Limit: 18000
    Active Sessions: 0
    Clients Not Tracked due to the limiting: 0
    Tags Not Tracked due to the limiting: 0
    Rogues Not Tracked due to the limiting: 0
    Total Elements Not Tracked due to the limiting: 0
    If the mobility services engine is not running, the command output looks like this example:
    com.aes.common.util.AesException: Failed to connect to server: http://localhost:8001
            at com.aes.client.AesClient.connect(AesClient.java:218)
            at com.aes.location.test.AesAbstractTest.init(AesAbstractTest.java:181)
            at com.aes.location.test.admin.AesTestGetServerInfo.main
    (AesTestGetServerInfo.java:75)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
            at java.lang.reflect.Method.invoke(Unknown Source)
            at com.zerog.lax.LAX.launch(DashoA8113)
             at com.zerog.lax.LAX.main(DashoA8113)
    Reference
    This document was generated from the following discussion: MSE platform status check up not working
    Content for Community-Ad
