The physical and virtual appliances that NCS and Prime Infrastructure run in can be monitored via SNMP. To configure the SNMP agent on the appliance, use the "snmp-server" configuration commands in at the global configuration level in the command line interface, as shown below.
appliance/admin# configure
Enter configuration commands, one per line. End with CNTL/Z.
appliance/admin(config)# snmp-server ?
community Set community string
contact Text for mib object sysContact
host Specify hosts to receive SNMP notifications
location Text for mib object sysLocation
The following MIBs are supported
as well as support of Cisco UDI (Cisco Unique Device Identifier)
As an alternative to using SNMP to monitor Prime Infrastructure, consider using Prime Infrastructure's REST API to monitor the uptime of the application. For more information, see https://developer.cisco.com/site/prime-infrastructure/documents/api-reference/rest-api-v3-8/v4/op/info/uptime-GET@_docs/
