Rollin Kibbe
The physical and virtual appliances that NCS and Prime Infrastructure run in can be monitored via SNMP.  To configure the SNMP agent on the appliance, use the "snmp-server" configuration commands in at the global configuration level in the command line interface, as shown below.
appliance/admin# configure
Enter configuration commands, one per line.  End with CNTL/Z.
appliance/admin(config)# snmp-server ?
   community  Set community string
   contact    Text for mib object sysContact
   host       Specify hosts to receive SNMP notifications
   location   Text for mib object sysLocation
The following MIBs are supported
SNMPv2-MIB
RFC1213-MIB
IF-MIB
IP-MIB
TCP-MIB
UDP-MIB
CISCO-CDP-MIB
HOST-RESOURCES-MIB
as well as support of Cisco UDI (Cisco Unique Device Identifier)
As an alternative to using SNMP to monitor Prime Infrastructure, consider using Prime Infrastructure's REST API to monitor the uptime of the application.  For more information, see https://developer.cisco.com/site/prime-infrastructure/documents/api-reference/rest-api-v3-8/v4/op/info/uptime-GET@_docs/
netops044
NCS 1002 supports what API's.
