alex bertran
trying to join a LAP1242 to a WLC 5508 for first time.
I am getting this error at the AP log. The Controller 5508 has the Policy to accept self SSC APs activated, even so I get this error...may you help? thanks!!
It is not an autonomous AP converted to LAP...it is originally a LAP1242AG.
The WLC has the software version 7.5.1.21
The AP gets its IP from a dhcp pool at the multilayer switch that acts as router with option 43...you can see it gets the 10.171.54.95 and learns the WLC IP 10.171.239.10
*Mar  1 00:00:07.469: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(25e)JAM, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 10-Dec-12 22:40 by prod_rel_team
*Feb  5 21:17:50.011: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Feb  5 21:17:50.011: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Feb  5 21:17:50.971: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Feb  5 21:17:58.399: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.171.54.95, mask 255.255.255.0, hostname AP0006.f670.8c8c
*Feb  5 21:18:12.379: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb  5 21:18:19.956: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.171.239.10 obtained through DHCP
*Feb  5 21:18:19.956: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Feb  5 21:18:28.957: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Feb  5 21:18:37.957: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Feb  5 21:18:47.958: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb  6 00:31:52.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.171.239.10 peer_port: 5246
*Feb  6 00:31:53.342: %DTLS-5-ALERT: Received FATAL : Certificate unknown alertfrom 10.171.239.10
*Feb  6 00:31:53.343: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Feb  6 00:31:53.343: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.171.239.10:5246
*Feb  6 00:31:53.344: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Feb  6 00:32:16.445: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb  6 00:32:57.000: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb  6 00:32:57.003: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Feb  6 00:32:57.003: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Feb  6 00:33:07.043: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb  6 00:33:07.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.171.239.10 peer_port: 5246
*Feb  6 00:33:08.334: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from 10.171.239.10
*Feb  6 00:33:08.334: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Feb  6 00:33:08.334: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.171.239.10:5246
*Feb  6 00:33:08.336: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Feb  6 00:34:12.000: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb  6 00:34:12.003: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Feb  6 00:34:12.003: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Feb  6 00:34:22.021: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb  6 00:34:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.171.239.10 peer_port: 5246
*Feb  6 00:34:23.342: %DTLS-5-ALERT: Received FATAL : Certificate unknown alertfrom 10.171.239.10
*Feb  6 00:34:23.343: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Feb  6 00:34:23.343: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.171.239.10:5246
*Feb  6 00:34:23.344: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination
.*Feb  6 00:35:27.001: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Feb  6 00:35:27.003: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Feb  6 00:35:27.003: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Feb  6 00:35:37.022: %CAPWAP-3-ERRORLOG: Go join a capwap controller
and so on and on...
