Non-root bridge loses association with parent
1342
Resolution
The following are possible reasons why a non-root bridge can lose association with its parent (or root) bridge:
  • Radio problems - Perform a carrier test to show if the channel in use is being interfered with. Resolve the antenna setup by referring to the RF Troubleshooting section of Troubleshooting BR350 Bridges.
  • Misconfiguration of the bridge - Verify that the configurations of the bridges match. In extreme cases, reset the bridge configuration to its default and reconfigure the bridge.
  • Firmware incompatibilities - To ensure IEEE draft standard compatibility, the root and non-root bridges should be running the same version of firmware.
Problem Type
Error message
Products
BR 340
BR 350
Content for Community-Ad
