Password Recovery for Workgroup Bridge
426
Core Issue
Password recovery due to lost password.
Resolution
The Cisco Aironet Workgroup Bridge (WGB) allows as many as eight hosts on an isolated wired LAN segment to share a single wireless connection to an access point in order to access other portions of the network.
Use the Reset button, a small hole on the back panel of the base station, to reset the base station parameters to the default values.
For more information, refer to the Workgroup Bridge section of the Password Recovery and Restoration of Default Settings for Cisco Aironet Equipment document.
Note: It would be a good practice to always backup the configuration file as soon as the device is configured so that the it can be used when access point recovers from a crash. Refer Working with Configuration Files for more information.
Problem Type
Password recovery
Products
Workgroup bridges
Content for Community-Ad
July's Community Spotlight Awards
