Poor throughput with the link status meter at fair or better
1156
Core Issue
The bandwidth available on the wireless link is largely dependent on the signal quality and the signal strength. If either or both are reduced, so too is the throughput on the link.
Resolution
Check the client-to-Access Point (AP) link by performing the following options:
  • Perform a link status test.
  • Check for interference.
  • Move the client around from location to location to check for changes in performance.
  • Re-survey your site.
The problem might not be a wireless problem. Congestion on the wired network to which the AP is connected can impact end-to-end throughput.
Problem Type
Poor connectivity / Performance
Products
Access point
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
Link Status Meter Test Result
Excellent
Good
Fair
Content for Community-Ad
