Receive the To "Temporarily DISABLING DNS lookups for 5 minutes " access point Log Message
713
Core Issue
The Access Point (AP) or bridge temporarily disables the Domain Name System (DNS) when it believes the server is having problems. When an AP/bridge is unable to connect to the DNS server, it disables DNS lookups and issues the following message:
(Warning): Repeatedly failed to connect to DNS Server.
Temporarily DISABLING DNS lookups for 5 minutes.
Resolution
These messages can be ignored . But make sure DNS server is reachable.
To re-enable DNS lookups immediately , select Disabled for the Domain Name System setting on the Name Server Setup page and click Apply. Then select Enabled and click Apply.
But When the access point re-enables the DNS automatically you recieve  the follwoing message  " Warning): RE-ENABLING DNS lookups. Lookups were suspended 5 minutes after repeated failures to connect to a DNS Server."
Problem Type
Error message
Products
Bridge
Access point
VxWorks Errors, Warnings, Statistics and Log Messages
Repeatedly failed to connect to DNS Server. Temporarily DISABLING DNS lookups.
Content for Community-Ad
August's Community Spotlight Awards
